Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Speedo fix ATTN: Blacky
  1. #11
    May 2008
    All I want, is to have my speedo closer than 13 MPH. Is it really that hard of a thing to program? There are what I would consider "junk" tuners out there, that can change MPH parameters....why is it such a big deal for Efi?????
  2. #12
    May 2008
    Speedo update...anyone???????/
  3. #13
    May 2008
    Another month....another bump
  4. #14
    Right now I am out of ideas for any additional changes to the speedo settings for Duramax trucks. I do not understand why you cannot change your speedo settings using the existing parameters that are available.
    Unfortunately, GM have used many different speedo calibration schemes and there is no easy way to tell which scheme is use din which vehicle. It may be a setting you need to change in the ECM, maybe in the TCM.
    Ignore the speed calculator, it may not work in your application. Try methodically changing one parameter at a time and noting any difference. Then, when you find a paramater that causes an affect on your speedo setting, you need to figure out which way to adjust it and by how much to acheive your desired reuslt. A few small trial and error steps should be enough to know which way to adjust it.
    Other than that I don't have any other answers right now. If we uncover any more information about how the speedo works then we implement it in the speedo calculator.
    Also, make sure you are using the latest version V7.5.5. And after installing V7.5.5 perform the "Check for updates" option to bring the installed software up to date.
  5. #15
    May 2008
    Thanks Paul....I guess there is just something weird about these Kodiak and Topkicks.
    I have tried using smaller adjustments...including different wheel sizes instead of 22.5 as a multiplier. Using different gear ratios makes no difference either. About the only thing I have not tried, is messing with the TCM.
    I guess I can pull out the cluster and just repaint the correct numbers on it. LOL
  6. #16
    There's every chance that changing the speed in the TCM will help.
  1. blacky please help
    By 00 truck in forum Gen III V8 Specific
    Last Post: July 31st, 2009, 09:48 AM
  2. Happy Birthday Blacky (yesterday)...
    By GMPX in forum Lounge
    Last Post: January 8th, 2009, 11:52 PM
  3. Attn: RedHardSupra. Could be of interest
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2007, 01:26 PM
  4. Attn: Sspddmon
    Last Post: September 15th, 2006, 10:02 AM
