Results 1 to 8 of 8
Thread: T43 DTC P0602 - Control Module not Programmed
    Dec 2007
    Default T43 DTC P0602 - Control Module not Programmed
    I am working on a truck A6 which has the 24239353 file from the factory. It is going into an LSX conversion so has not been run in a vehicle yet.
    The T43 seems to operate fine, read and writes ok, but keeps raising P0602 every time the ignition is cycled.
    Reason for DTC...."The PCM does not contain the correct program required in order to operate the vehicle."
    Has anyone had experience with this code on this or other controllers and knows whether it is harmless or the T43 is really got some brain damage?
    I know what the GM flow chart says...which is that it has not been programmed, but it does have a valid OS and full set of calibrations so there is something in there.....
    Thankyou.
    Dec 2007
    Anyone? Difficult to see this as never having come up before?
    Thanks.
    Lifetime Member MN C5's Avatar
    Mar 2005
    TTT for ya wish I could help.
    I already pm'd Ross, we'll see if he can figure this out.
    Dec 2007
    Thankyou MN C5 and JoeCar. Most appreciated.
    It's not a problem with EFILive, but the truth must be out there somewhere on the TCM behavior with this one.
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    You need a full flash to change the full T43 operating system rather than just the calibration i think.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    So the Trans has never been in a 'real' vehicle?
    What file are you trying to flash?, the one read from the TCM?
    There is no need to change the OS, it just needs some valid calibrations put in it.
    The OS you have is the best choice anyway because it was shared over nearly all GM platforms.
    Dec 2007
    Thanks Ross, correct, never been in a real vehicle. Have not attempted to flash anything other than the VIN (successful) to see if the P0602 DTC went away. Change to a "relevant" VIN (from zeroes) made no difference to P0602 . But then again maybe it was not meant to in the ECM scheme of things.
    Cheers.
  1. C0558 Trouble Code: "Calibration Data Not Programmed"
    By dc_justin in forum General (Petrol, Gas, Ethanol)
    Last Post: February 29th, 2012, 10:54 AM
  2. DBW pedal and TAC module differences
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: September 17th, 2009, 06:09 PM
  3. P0601 "Control Module Read Only Memory (ROM)"
    By WI Huck in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 23rd, 2009, 02:51 AM
  4. body control module on v6 2002 camaro
    By Aint Skeered in forum EFILive V6
    Last Post: July 16th, 2008, 12:12 AM
  5. Module Licensing question
    By Cougar281 in forum Purchase and Shipping
    Last Post: August 28th, 2006, 02:59 PM
