Results 1 to 3 of 3
Thread: Dashboard guages issue
    Feb 2004
    Default Dashboard guages issue
    I was setting up a dashpage from scratch and was putting in a digital guage for KR. I resized the sections to give the value section most of the area, but it still stayed at 12pt font even with auto-size checked. I tried changing the font to a larger point size on that same tab, but when I change a font setting for anything other than Title and click ok on the font dialog when it returns the selection jumps up to Title and the font settings are applied to Title. I can set Title to a big point size and then use the Same button to put those settings on the other parts, but I can't edit anything after Title. On 7.5.4 build 56, winxp pro sp2.
    01 C5 'vert A4
    EFILive, PLX, & TNT are all we got at the moment.
    I've been trying to reproduce the problem that you described but I cannot.
    Can you reproduce it every time? If so can you please provide a detailed step by step process to reproduce the problem?
    Feb 2004
    Well, I installed M$'s updates and rebooted and now it doesn't do it anymore. Sorry for the false alarm.
    01 C5 'vert A4
  1. Looking for dashboard thats in the manual!
    By Redline Motorsports in forum General
    Last Post: September 12th, 2007, 04:04 AM
  2. Will not start No guages, nothing
    By cliffy v in forum Gen III V8 Specific
    Last Post: May 10th, 2007, 12:25 AM
  3. Another TDC day, Hey I need a new Dashboard
    By NewV in forum Tips and tricks
    Last Post: January 18th, 2007, 02:48 PM
  4. Custom dashboard
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2006, 05:32 PM
