Results 1 to 5 of 5
Thread: Vats Ign Cycles
    Oct 2007
    Default Vats Ign Cycles
    I have tried to use the vats ignition cycles and I get this message
    COULD NOT SET IGNITION CYCLES>
    MOST CONTROLLERS WILL ONLY ALLOW
    IGNITON CYCLES TO BE CHANGED IF NOT ALREADY ZERO.
    I would have thought all programs would have a default setting of zero???? any help would be appreciated.
    Yortt
    VAT ignition cycles is usually only non-zero while the vehicle is in production at the factory. That allows various operations to be performed on the ECM without the technicians having to be concerned about security issues. The VAT counter should be set to zero by the time the vehicle leaves the factory. If (for some unknown reason) the vehicle leaves the factory with the VAT counter left at non-zero, it counts down to zero at each ignition cycle. That means within a short amount of time the vehicle will return to full secure mode. Once the VAT counter has reached zero it cannot be increased above zero again.
    It is most useful when a new PCM is installed in a vehicle and that ECM might have a VAT counter value of 200 or more. Instead of cycling the ignition 200 times you can just set it to zero using that option in EFILive.
    Oct 2007
    Thanks for the reply, I am however confused as a post by Delco whos explanation on what he is doing is some what different IE.
    http://www.ls1.com.au/forum/showthre...ht=Vats&page=2 post 25
    "No it will start and run instantly if setup properly , it wont lock onto the final secuiry code for x amount of key on , if the PCM was setup for only 1 key on and that was done on the bench then it will not link to your car.
    We normally set our mailorder tunes to link on the 5 key on , up to that point it will start and run but the antitheft is not active. So in effect you could put the PCm inot 5 different cars and each would run but by the 5th car or key on it would stay locked to that car."
    Can I do this??????
    Yortt
    When you full flash an LS1 controller you get an option to set the ignition counter to a value other than 0.
    Oct 2007
    Thanks for the prompt response, I done some work on the bench yesterday and I tried a full relash and still did not work, obviously I did something wrong I wll try again.
    Yortt
  1. Warm Up Cycles Emissions...
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: April 19th, 2010, 12:08 PM
  2. Cadillac vats ?
    By RPO_Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2009, 03:41 PM
  3. LBZ/LMM VATs
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 22nd, 2007, 09:56 PM
  4. Injector Duty Cycles 298%!!!!!!!!!
    By CTP Racing in forum General (Petrol, Gas, Ethanol)
    Last Post: July 19th, 2006, 11:08 AM
