Results 1 to 10 of 12
Thread: Flash scan + efilive 7.0
    Nov 2003
    Default Flash scan + efilive 7.0
    I am ready tp purchase flash scan and download 7.0. Presently I have EFILive 6.0 pro version.
    What I am unsure about is the following. I have three PCM for our
    2000SS:
    Oiginal PCM, modified only to lower fan temperatures a bit and allow revs to go to 6400 rpm. Given my mods I meet emissions in NY with flying colors with this one.
    Tuner PCM which inlcudes programming for my heads/cam, LS6 intake,
    ported TB, shorty headers and other std. bolt ons.
    An stock programmed pcm which has version updates for the 2000 model year, no other chnages. This is my back-up.
    Can I modifiy with the single personal license all three PCMs. They all
    are configured to work in my car? Or do I need to pick one for tuning with flash scan?
    Gert
    Hi Gert,
    If you want to program all three then you will need three PCM licenses.
    2 will ship with the cable as standard and you can purchase a third for $99.00
    However, the days of "spare" PCMs are numbered. With EFILive you can just keep the three different tunes on your laptop and reflash whichever one you want before you drive out of your garage - it only takes 30 seconds.
    I'm pretty sure you can't swap out a PCM for a spare in those 30 seconds.
    Lifetime Member Steve Bryant's Avatar
    Feb 2004
    Amazing! 8)
    I didn't realize that it would be that quick!
    Steve
    Nov 2003
    Thanks for the explanantion. The two included PCM licenses will obviously suffice in my case. I'll put the third PCM on ice for study by future
    generations of automotive historians....
    Gert
    Nov 2003
    Hello,
    I downloaded the evaluation software. I think it should work with the
    old atap interface - the flash scan interfaceis not available yet.
    Is any of the tuning supposed to work at this point - I tried but none
    of the menues seemed to be activated?
    Gert
    Feb 2004
    Gert,
    No, the tuning functionality won't work with any of the old Autotap interface cables. Do you have any questions about what you've seen thus far?
    Regards,
    Steve Bryant
    Have you opened a *.tun file in the Tuning Tool software?
    The sample *.tun files are located in My Documents\EFILive\V7\bin
    Nov 2003
    I am mostly interested in the tuning capability - I am pretty happy
    with V6 pro and, as a matter of fact, only use probably 20% of the
    functionality of that program (monitoring key parameters, log files,
    and using some of the bidirectional features from time to time).
    If I notice anything which is particularly noteworthy I can share it here,
    Gert
    Quote Originally Posted by 2000ssnb
    Hello,
    Gert
    I forgot to add that you can't use the V7 Scan Tool to log data using AutoTap interfaces until we issue V7 upgrade licenses.
    We will do that once the product is shipping.
    Jun 2004
    Question????
    Will black box data logging be restricted to the registered vin or will it be open to use on any vehicle?????
  1. Where is Flash Scan update 2.04.57?
    By Spindoctor in forum General (Petrol, Gas, Ethanol)
    Last Post: February 6th, 2008, 01:49 PM
  2. Flash Scan Support LS2?
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2005, 09:15 PM
  3. Neat flash scan tip
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: February 26th, 2005, 05:58 AM
