Results 1 to 10 of 10
Thread: Anyone used Version 7.3 yet?
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Default Anyone used Version 7.3 yet?
    I just installed the latest release 7.3. Can you not rotate the 3-D graphs with the mouse anymore? I am just trying it on my DeskTop right now. I will try on my notebook later this evening.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Sep 2003
    Click and hold the right mouse button to spin the graph
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Press the "?" button in the top right corner of the window you're currently viewing.
    Nov 2003
    Switched mouse keys. Just got it installed on my notebook.
    Thanks,
    Bill
    Jan 2005
    I uploaded a new tune and did a logging session. Works great so far.
    Nov 2003
    Just did my first logging. A lot of idle PIDs; LongTerm/Short Term Correction. I logged some of them but am not sure what I am looking at. Is this number grams/s that your IAC's are off? How do you correct the numbers that are off?
    This has got to help us with cams.
    Good work EFILive!!!!
    Bill
    Sep 2003
    You have to make a calc pid LTIT-STIT and map them against ECT in order to find out how far off you are
    Larry - HumpinSS
    Jan 2005
    I've got to get my bird back on the ground to try this new stuff out!
    Quote Originally Posted by BowlingSS
    Good work EFILive!!!! :D :D :D :D :D :D :D :D :) :) :) :)
    Bill
    Right click on the PIDs in the [PIDs (F8)] tab page and select "More info.." - that shows which tuning tool calibrations control the idle PIDs.
    Changing the idle calibrations is not trivial, there is a lot of interdependence and there are many calibrations, each adding/subtracting little bits of airflow from the final desired IAC airflow.
    Lifetime Member mistermike's Avatar
    Dec 2003
    Early stage of 2 bar tuning is working beautifully. I can't comment on idle stuff, coz I'm not that experienced yet. Highlighting the surface maps and having it show up in the table is a dream. If you have one or two "lumpy" cells it's probably just as easy to knock them down manually, and this makes it a breeze.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
  1. Version 7.4 won't go away
    By 01Z in forum FlashScan V1
    Last Post: October 3rd, 2009, 10:20 AM
  2. LS1 version 2
    By ws6togo in forum Lounge
    Last Post: April 19th, 2006, 05:31 AM
  3. Version 7.3
    By jamesbond2509 in forum General
    Last Post: October 16th, 2005, 01:15 PM
