I've been tuning my 96# low impedance injectors for a while. I do have an AEM driver to run these on my Vette. Has anyone got experience with a similar setup? Did you change the small pulse threshhold or battery voltage correction factors? Any other tables having to do with injector timing and small pulse adjustments that you changed? I figure since these are low impedance (fast acting) and running from a driver, then a lot of these tables may need to be changed.
Derrick
