Results 1 to 3 of 3
Thread: Strange flash counts
    Lifetime Member Scoota's Avatar
    Mar 2005
    Default Strange flash counts
    I was just going into the V2 licensing to add some more licenses to find I've been quite busy.
    I've not quite been that busy.
    Anyone else noticed this on their units.
    Cheers Scotty.
    It's a lot easier to ask for forgiveness than it is to ask for permission.
    It's a bug (in an older version of the software) in the way the data is displayed in those fields. The byte order of the 16 bit values is being switched when it should not be. Both the Infineon CPU in FlashScan and the x86 CPU in the PC use the same byte order. The bug was a hangover from code copied from FlashScan V1 that used an Atmel CPU with a reverse byte order.
    You can convert the displayed values to their true value as follows:
    32513 is $7F01, it should be $017F which is 383 (cal flashes)
    5632 is $1600, it should be $0016 which is 22 (full flashes)
    Mar 2005
    That sounds about right paul.
    Cheers Scotty.
  1. IAC counts
    Last Post: December 17th, 2008, 05:24 AM
  2. Question on PID counts when logging
    Last Post: June 5th, 2008, 03:22 AM
  3. CL Mode counts??
    By Hyper99 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 28th, 2008, 08:58 AM
  4. Cell counts in BEN map
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2007, 10:36 AM
  5. How to filter low cell counts?
    By Teutonic Speedracer in forum General
    Last Post: March 22nd, 2006, 12:39 PM
