Got a chance to get the car on a dyno ... I have a pretty decent setup in the lower RPM range (<3000) through regular driving on the street, AFR has gotten close to the +-1% range ... I'm still off in the higher RPM ranges, though running richer ...
Can somebody give me a short run-down on how to get the higher RPM AutoVE done on the dyno?
Also, the next step I guess is the timing setup through BiDi ... any hints on that?
Thanks!
