Results 1 to 10 of 18
Thread: Problems with AEM Uego serial logging....
    Jan 2007
    Default Problems with AEM Uego serial logging....
    I just got my V2 up and going, I am currently on the April 26th update for BBlogging. When I connect my cable to the wideband the second LED from the left lights up, it does not blink, just stays lit.... I choose the AEM Uego from the edit menu, then I select the 99+ LS1 PIDs, then I choose display Wideband and I get error 3072.... Any ideas... Both Com settings are set to Wide 02....
    Jan 2007
    I am up to the latest release now, both boot block and firmware and the updated Config files. I am not getting the error 3072, not it just says controler not found, but the led is lit... Any help would be appreciated, I know I am a little late getting on the BB Logging...
    Nov 2006
    how does the WBO2 connect to your V2?
    is it a direct plug in or are you using a null modem?
    a regular gender bender does not work.
    Jan 2007
    Well I read the AEM documentation and it said to connect the serial output wire to pin #2 and ground to pin #5... That is want I did, I wish it had a pre-made end like the Innovative products...
    Jan 2007
    Here is the documentation from AEM
    http://www.aempower.com/images/products/10-4101.pdf
    Jan 2007
    Any ideas?
    May 2008
    I have not tried logging with my AEM UEGO yet. I was waiting for the next software which can display the raw data.
    I should be able to give you a wiring schematic of what I come up with if needed. Hopefully this weekend if I get my motorcycle back together in a reasonable time.
    Have you tried hooking the AEM up to the PC using hyperterminal?
    Prick, it comes with bare wires, no connector, so as long as TX on the AEM is connected to RX on whatever is reading, it should be OK.
    Jan 2007
    Quote Originally Posted by nevinsb View Post
    Unfortunately I can't hook it up to my laptop, cause it does not have a serial connector on my laptop, only USB, also I am running vista so no hyperterminal... I have found plenty of diagrams and examples on the AEM forum on how to wire it up, so that is not a problem. Honestly I think it is the software...
    I need to add a correction to the first and second post... If the serial wire is connected to pin #3 then the second LED from the left lights up, if the pins are connected correctly (#2 and #5) then the LED turns off.
    The next update is due for release this week. It has the capability of logging the raw serial data to a trace file. Once you have the new firmware in FlashScan, hook up the AEM and allow FlashScan to read the data for about 5 seconds, then save a trace file using menu: F2 Scan Tool -> F3 Scan Options -> F1 Save Trace file. Then use EFILive_Explorer to copy the trace file to your PC and then send it to me at paul@efilive.com
    Jan 2007
    Cool, I will get you the trace file, thanks for the support!
  1. Tutorial: FlashScan V2 Serial Wideband Logging
    By TAQuickness in forum Tutorials
    Last Post: July 22nd, 2015, 10:47 AM
  2. BEN is only for analog, right? How do I log BEN with serial logging?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2009, 06:08 PM
  3. Using inverter for laptop + FS V2 with serial logging
    By Dopey in forum FlashScan V2 BB Logging
    Last Post: September 10th, 2008, 08:37 AM
  4. Need Help w/LC1 Serial Logging
    By TFZ_Z06 in forum FlashScan V2 BB Logging
    Last Post: August 4th, 2008, 03:35 PM
  5. LC1 Serial Logging
    By oztracktuning in forum General
    Last Post: November 8th, 2005, 06:45 AM
