Results 1 to 6 of 6
Thread: Error Report.
    Mar 2008
    Default Error Report.
    EFI Live V1 will not start up. It says the cable is not plugged in when I have it in. Here is the report.
    Error report generated by EFILive at 07:34:06 on Jun 04, 2008
    Error code: ERR_WIN 0/0
    Cannot open file "C:\Users\Anthony Morgan\Documents\EFILive\V7.5\User Configuration\calc_pids.txt". The system cannot find the file specified
    EFILive Version: 7.5.3 (Build 36)
    Platform: Windows NT
    Version: 6.0 (build 6001)
    Processor type: Pentium 1996MHz
    Directories
    Temporary Cache: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Temporary cache
    Logged Data: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Logged data
    Customers: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Customers
    Configuration: C:\Program Files\EFILive\V7.5\Configuration
    Exported Data: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Exported data
    Images: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Images
    Sounds: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Sounds
    Maps: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Maps
    Pids: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\PIDs
    Virtual Dash: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\VDash
    Print Reports: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Print reports
    Bug Reports: C:\Users\Anthony Morgan\Documents\EFILive\V7.5\Bug reports
    Connected: No
    Auto connect: No
    Scan OBDII info: Yes
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: Read alreadxxxxxx (Note: 1)
    PCM information
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Stream-Slow scan mode: Unknown
    Stream-Fast scan mode: Unknown
    Maximum dynamic packets: Unknown
    Most recent communication with vehicle:
    Report ID: 152867 (Note: 2)
    Notes:
    (1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
    (2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
    Mine2001 GMC 2500HD EC/LB, D/A. 4in MBRP exhaust, AFE Stage II w/Amsoil Ea air filter, ISSPRO boost/Pyro guages, PPE Boost Valve, EFI Live V2, Maximum OD Stage 2 Trans, Amsoil throughout, AirDog150, modded intake horn.
    540HP/1056TQ
    Dyno'd Danville Performance
    April 5th 2011
    Hers: 2006 GMC Envoy XL Denali, Flowmaster 40 with a bullet style resonator in the back, EFI Live with the help of JoeCar and other great members here.
    Mar 2008
    It also shuts down instantly!
    Tony
    540HP/1056TQ
    April 5th 2011
    Tony, I pm'd Tech Support.
    Oct 2004
    On Vista machines you need to run the application (one at least) as an Administrative account'. Vista changed the default security permissions in the 'C:\Program Files\..' folder structure, which causes users to not be able to create files.
    You can right-click on the Tune Tool icon and choose 'Run as Administrator'.
    Andrew
    EFILive Crew
    Mar 2008
    I have not changed any settings on this laptop to date since the day I first installed.
    I reinstalled/repaired the program from the download section of EFI Live. Now it seems to be working fine, thanks for the help.
    Tony
    540HP/1056TQ
    April 5th 2011
    Mar 2008
    I am merging this thread with the one that Ross has already tried helping me with. Support team, I want to help figure this out incase it is not just my laptop that is doing it. I have a fealing others have this problem, but havent seen it yet.
    Thanks,
    Tony
    http://forum.efilive.com/showthread.php?t=8080
    540HP/1056TQ
    April 5th 2011
  1. Problem report: 08 E38, BBL, TCS/AH trouble
    By Tony @ MPH in forum Black Box Logging
    Last Post: February 29th, 2008, 08:52 PM
  2. Can anybody confirm that GM map sensor #12580698 will report up to 260kPa?
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 19th, 2006, 04:06 AM
