Results 1 to 7 of 7
Thread: Can't open log files anymore...
    Jan 2007
    Default Can't open log files anymore...
    Any ideas on what I did???
    I believe I have every update here.
    EFI LIVE says 5.5.3 build 36.
    I have the may updates installed.
    what is it going to take to get the log file to read??
    The message is wrong when it says 7.5 or later. You need to be running V7.5.4 or later.
    You can download the latest V7.5.4 here:
    http://forum.efilive.com/showthread.php?t=8103
    Note: a new V7.5.4 update will be available in the next day or two, please check back for the update as it contains new features and bug fixes.
    Jan 2007
    I am going to try that anyways. I did notice your thread to stop posting about bugs but I thought mine might not be related.
    Anyways, trying now...
    Making sure I have the lastest BB and firmware....
    I have:
    bb 2.5.08 and fw 2.5.17
    Is this good?
    Jan 2007
    Also for some weird reason in my directory structure I have .pmms in two different places
    v8
    == boot block
    == config
    == efi live hapi
    ===== config
    ===== images.....
    I am using the set of .ppms that have mostly 5/20/2008 dates.
    Jan 2007
    OMG this is super hard to explain but after awhile of straining my eyes [dead beat tired right now] I think I have figured it out.
    There is some weird directory thing going on. I found an exe that will load the log files just fine.
    the old exe didn't get overwritten.
    Hard to explain but I see it now.
    Sorry for fudging up the board, Blacky!! TY
    One of the more recent updates changed the folder structure to remove the EFILive_Hapi folder. You should delete that folder and everything in it.
    If fact I highly recommend deleting the entire V8 folder and everything in it.
    Save any changes you've made to Options.ini before you do though.
    Then unzip the zip file again and all the correct files will be in the V8 folder.
    Jan 2007
    Done and Done. I overwrote the old .exes also. Everything looks to be working now.
    I might of pasted the 7.3/7.5 patch or whatever in the wrong directory whenever I recently redid my computer. I tried to get back to where I was very fast. I need to just give in and buy norton ghost.
    Everything looks good now. Dir structure is clean. Maybe I needed a reality check!
  1. Need some help: Can't view Dashpage anymore
    By DrkPhx in forum General
    Last Post: November 28th, 2009, 01:23 PM
  2. Can't log serial wideband anymore
    By white01ss in forum Tutorials
    Last Post: October 28th, 2009, 09:39 AM
  3. Can't open BB logging .efi files with latest scan tool
    By Neptune in forum Black Box Logging
    Last Post: May 22nd, 2008, 02:52 AM
  4. Cant Open Tune Files
    By blownlt1bird in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2007, 02:06 PM
  5. Open Black Box Files
    By RevGTO in forum Black Box Logging
    Last Post: October 16th, 2006, 02:50 PM
