Did you copy the Primary table to the Alternate table before you adjusted the 3%? I noticed on mine the alternate table was much lower than the Primary. The Alternate is the table that is running when you have traction control off or are running in Comp mode. It seems to me that this is when you want all of your throttle response. It is also weird to me that the table isn't just one to one. So the percent of throttle is the actual percent the throttle opens. I only get this because from 93% or so the table goes 100 so at that point the table values become real values.
