I am going to be going SD with the new 7.3 release and it seems I need to pick up a GM 2 bar Map sensor from my reading. From my research the part # to get is 12580698.
Can someone please confirm this for me? Thanks.
If you are not running any boost you are NOT going to need it.
That is the correct part number. It's from a saturn ion redline, IIRC.
2001 Camaro SS
EFILive Custom OS3
I will be running boost, max of 14 PSI through TTI Stage II Twin turbo setup on a 2000 C5 corvette.
Is that also the same 2 bar sensor out of say a Monte Carlo SS?
2000 Corvette Twin Turbo
2004 CTS-V TVS 1900
2006 TBSS TVS 1900
All Tuned by
Rad Tunes by Troy
aka Vetteboy2k
