Results 1 to 10 of 19
Thread: AutoCal Beta
    Jan 2005
    Default AutoCal Beta
    For reference, my AutoCal beta unit arrived with no cables- not a problem because you can borrow the necessary cables from a V2. Not knowing what to expect, I plugged AC into a vehicle and received a "No PIDS" selected message, whereupon I plugged it into my laptop to download some PIDs. Tried to down load them and received a 0182 error code. So I used EFILive Explorer to format the "Config" area of AC memory and then I downloaded the Options file along with the pmm files I plan to use. (Same files as I use in V2.) Plugged AC back into a vehicle and selected "Display Data" and everything worked fine. Then I tried to log data and received a 0185 error. Next I plugged AC back into my laptop, selected the "Scan Files" tab and got another 0182 error. I couldn't find any way to format Scan Files memory with EFILive Explorer so I started snooping around AC and found a "Format File Sys" option. (After plugging AC in, scroll down to "AutoCal Options", select it, then scroll down to "Format File Sys".) Everything appears to be working properly now.
    Update- Dragged the log file from AC into my laptop. The file opened fine and displayed data accurately. Suggestion: Make the default file name other than BBL (ACBBL perhaps) to avoid file name conflicts between V2 and AC data logs.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Thanks for the post. I didnt know about the format file sys option in AC.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Good detective work Dave
    Right now, AutoCal is set up to mimic the behavior of FlashScan, so what you do for FlashScan BBL you do the same for AutoCal.
    The menu structures (including the format file system option) are shown in the attached file
    Quote Originally Posted by dfe1 View Post
    Interesting idea - I had not thought of that.
    Meanwhile you could set the File # in the AutoCal settings to a large value (i.e. 50000). That would create two "name spaces":
    1. FlashScan from 00000 to 49999
    2. AutoCal from 50000 to 99999
    Note: Changing that setting by 50,000 using AuotCal's keypad could be a bit tedious... Those settings will all be configurable from the PC eventually.
    Jan 2005
    Either AutoCal has developed a mind of it's own, or my memory has developed a mind of its own. As I remember it, the first time I changed settings, they were permanent. Now, it won't retain any changes except date and time. I tried "Restore Settings", which reset the file counter to 0, but if I change that, units, or Lo-Power, the changes only stay as long as power is applied. Once the unit is unplugged and plugged in again, all values have reverted to their default settings. Am I remembering incorrectly- do these values have to be reset every time AutoCal is plugged in?
    678/344-1590
    The Settings.dat file on your AutoCal may be from old version of firmware.
    Try deleting the Settings.dat file from the [Config] tab page in the EFILive_Explorer program for AutoCal.
    Actually it would probably be better if you formatted the [Config] file system using the [Format] button on the same screen.
    Then power off AutoCal and repower it and change one or more settings.
    It should re-create the settings .dat file with the correct format for the current firmware.
    Jan 2005
    I reformatted the config file system, reloaded the firmware and tried again-- several times. Autocal does not create a settings.dat file so changes still don't stay after power is removed. Can I create a settings.dat file and move it to AutoCal, or does it have to be "The Creator"?
    678/344-1590
    Hmm, I'll take a look at an AutoCal here. I may have messed up something in the AutoCal firmware.
    You could create a settings.dat file, but if AutoCal is not writing to it them it probably won't do you much good.
    You could try copying the Settings.dat file from FlashScan - the files are identical.
    Jan 2005
    Don't have one of those either. I remember seeing a settings file, but I can't find it any more. Maybe when the bit bucket overflowed, I lost it.
    678/344-1590
    I just tried it with the latest firmware - it fails here too. I'll fix it :(
  1. Autocal
    By Frost in forum Lounge
    Last Post: May 10th, 2010, 01:27 PM
  2. AutoCal Beta Test - Apply Here
    By Blacky in forum Do you want to be a Beta Tester?
    Last Post: February 27th, 2009, 11:18 AM
