How/where do you modify the 'steps' for the IAC? I see airflow in Grams/Sec but how does that get converted to steps?
The problem is 2 fold:
1) After the burnout the idle drops to 500-600 RPM and it take quite a while before the idle gets back to normal. During this time the IAC steps flatlines at 199 then after a while it goes to 240 and the idle is fine. During the time it's flatlined at 199 the timing is also flatlined. Once the IAC steps start moving so does the timing. I have drilled out the hole in the throttle blade yet I have to open up the blade a ton.
2) When it's cold started the idle is lower then commanded. I've played with B4307 and it doesnt seem to help.
Lee
