I put long tubes on my 6L GTO. Now it seems to stumble and surge slightly after I push in the clutch approaching a stop sign. Even worse if the air conditioner is on.
Throttle follower/cracker adjustment? I was thinking of adjusting the VE cells (B0200) to match from 1200rpm and below using the stock 1200rpm settings. Just wondering what you would do? I know it is probably an easy fix.
Chris
