Hi All,
Not sure if this is the appropriate forum....
Just fitted 1-7/8" long tubes to my LS2 (E40). I'm now seeing knock at the top end and even when blipping the throttle when stationary.
I was anticipating the lower back pressure if anything to need more timing. What are the usual tweaks that are required with this change?
Hopefully refitting the wideband shortly to change the ratios.
Any help much appreciated, got a long road trip later this week, and would like to bottom out any running issues before if possible.
