Results 1 to 6 of 6
Thread: VE multi
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default VE multi
    OK, two years after starting tuning LOL I m just as confused...
    You have the MAF table B0120 set to 4000
    So your playing with VE table (increasing for more fuel) to tune out KR in the upper MAP (70-105) and VE multipliers, but isn't a mute point if @ 4000 the Maf table takes over?
    I can get the COS 5 timing pull to work, but I am not having much luck seeing the VE multiplier kick in (1.1 or 1.2 in places...)
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Feb 2008
    Out of curiousity to all your timing tables match. I always had issues if the High/Low/Base Spark/ and Optimal tables weren't one in the same.
    Oct 2007
    simple ditch the maf...
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
    Jul 2006
    Quote Originally Posted by WHYTRYZ06 View Post
    So COS 5 VE multiplier is for SD only? Kind of defeats the purpose of "Nitrous Monitor"...???
    Maine USA
    Oct 2007
    Quote Originally Posted by Beer99C5 View Post
    i didnt say that.. im not 100% sure on that one.. but i'd ditch the maf anyways
    Jun 2007
    Beer, so whats it gonna take to talk you into a few suny day's in Florida
    WWW.EFIAlchemy.com
  1. Replies: 6
    Last Post: April 27th, 2006, 06:26 PM
