Results 1 to 2 of 2
Thread: PLX wired to EGR question
    May 2008
    Default PLX wired to EGR question
    so ive done some searching but didnt find anything. How do i wire a plx-smafr into the EGR so that the roadrunner can use the wideband for auto tunning?
    Jan 2005
    From the scan or tune tool, click Help > Tutorials > LS1 Fuel Pressure Sending Unit Tutorial.pdf
    In this case, you'll be wiring up a WB instead of a FP sending unit, but the hardwiring and PCM configuration will still be quite applicable. You will need to create your own custom PID to accurately convert your WB voltage to AFR though.
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
