I'm failing!!
I'm trying to do the RAFIG process and I'm running into trouble. Here is what my options file looks like:
PCM, ECT, -40:110:1:1:0
PCM, MAP
PCM, RPM, 0:6500:2:1:0
PCM, SPARKADV
PCM, TP
PCM, AFR
PCM, KR
PCM, IAC
PCM, AD1
PCM, IBPW1
-, IAC_STD_M
-, IAC_LTD_M
-, DYNCYLAIR_M
-, DYNAIR
-, CALC.BEN_LC11
-, CALC.AFR_LC11
I'm getting no data from the IAC_STD_M and IAC_LTD_M so I'm guessing they are looking for a MAF signal. Can you show me what I'm supposed to be logging the the flashscan V2?
