Results 1 to 4 of 4
Thread: LS1 PCMs
    Mar 2007
    Default LS1 PCMs
    Can someone tell me what the difference is between the PCM with the blue and red pcm connecter and the one with the blue/green connectors. Will the One with Blue/ Green connector still work OK??
    Mike
    One is a 512k pcm as used on the cable thottle motors here in Aus , the other is the 1024k PCM used with the drive by wire setup , not interchangable
    Mar 2007
    Thanks, so the 512pcm will not do drive by wire? (we use all cable). Do they use the same cam and crank signal?
    Mike
    Yes same crank and cam signals , the 512k pcm was able to run FBW but it is different to how it was done here in AUS on the 1024k pcm
  1. list of 411 pcms anyone?
    Last Post: April 19th, 2010, 10:49 AM
  2. Vortec PCMS
    By chevy052500hd in forum Custom Operating Systems
    Last Post: March 11th, 2008, 01:52 PM
  3. lbz pcms for sale.
    By wait4me in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 16th, 2007, 03:14 PM
  4. RR and 98' PCMs..
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 13th, 2007, 01:09 AM
