You have zeroed out your throttle follower decay which would cause your idle to hang. I would reset these to stock values at the moment.
As Delco has stated you need to get your fuelling & spark dialled in before messing with the rafig etc. Spark has the most control over your idle as the iac valve moves too slow to make the immediate adjustments necessary. For starters find the best timing & afr for idle with the BIDI controls, Then remove a few degrees & put this timing in the cells you hit at idle. This will give you room to make spark corrections to your idle speed by either increasing the spark in the lower rpm cells or using the spark over/ underspeed correction tables.
