I got the Holley wired up correctly now, it took some time but it has 4 pins, the 2 outside are one coil and the 2 inside is the other, unlike the stock one. What really helped was going into the bidirectional menu and commanding the IAC up and down. Once it was right (0 = closed air or extended plunger) I got things going pretty good.
Now the problem:
When I zing the throttle the IAC opens fully racing the idle to over 2000RPM, after 5-10 seconds it starts to close and comes back to a normal idle.
I've made so many changes to the tun I dont know what's up or down. Can someone help with this? I just want a little IAC action when I zing it so it wont die after a burnout otherwise it's just there for cold startups.
Keep in mind this is in a dragster and I've tried to eliminate most of the correction tables that I could find, epsecially in the fuel and spark, I just want X fuel and X spark at idle and WOT.
