Page 5 of 5 FirstFirst ... 345
Results 41 to 41 of 41
Thread: AutoVE verification file & PID log questions
  1. #41
    Mar 2008
    Here's tonights' log & tune file. Found a tune in the repository that had the same knock sensors & different knock sensor software settings. The attatched log is recorded w/ the new software settings. Also the tune used in the log has advanced spark settings. There was no knock retard & I could not hear or feel any pre-detonation. Perhaps the knock sensor software settings copied from the original stock file were too sensitive?
    Comments? Anyone see a problem?
    Also, the WOT A/F is near perfect w/ the modied commanded A/F. Spoke w/ a tuner whom said that he has had past trouble tuning w/ the original Accel 30# injectors. He further stated that he had no trouble tuning with the "newer" 30# Accel injectors. Mine are 99-2000 vintage; don't know if that's newer or older model. However, I do know that the commanded A/F ratio had to be leaner than 1.13 EQ in order to result in a 12:1 A/F ratio @ WOT. Have adjusted the normal driving VE table based on this log (filtered). Have also increased the timing a bit more for the next log test.
  1. AutoVE Questions
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2007, 11:06 PM
  2. LL8 I6 AutoVE questions
    By blandmiller in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2006, 10:49 AM
  3. Looking for 100% verification on compatibility.
    By 2kwik4u in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2006, 03:57 AM
  4. AutoVE - 3 questions I need help with
    By Learning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 16th, 2006, 09:40 AM
