Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 82
Thread: BBL installer update: June 12, 2008
    Quote Originally Posted by BlackGMC View Post
    Will this update allow me to do this:
    Yes, this version saves the serial port data to the trace file.
    Paul, did the .mls feature ever work...?
    It should be working, is there a specific problem with it that I don't know about (or have forgotten about)?
    Oct 2005
    In the Options.ini file it the hotkeys should be 1, 2, 3 and 4 not F1, F2, F3 and F4.
    The options.ini does show 1,2,3,4 but the V2 shows F1,F2...and it does not work for me either.
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    I'll test it.
    Quote Originally Posted by Lennart View Post
    Correct, make sure you're pressing Ctrl+F1,not just F1.
    Also make sure that you can select those PIDs via the menu.
    Ahhh... Ctrl+F1 instead of F1... I get it...
    Also make sure you've got a comma in the Options.ini file before the hotkey designator,
    Under the PIDs tab I open TEST-CAT.pid, and when I goto the MAP tab nothing has changed.
  9. #19
    Ok, that seems to work everywhere except when viewing the Select PID List menu...
    The Select PID List menu shows one of F1, F2, F3, F4 next to four menu items...
    pressing ctrl+Fn or Fn doesn't seem to do anything while on this menu...
    but, the usual method of highlighting a PID list and pressing OK works.
  10. #20
    Mar 2008
    Not wanting to "mess this up" I am running V2.05.08 (0426) & 2.05.17 (0519) which are not mentioned above. Should I be changing "back" to the ones mentioned above before installing V7.5.4 & V8.1.1? HELP!!!
    JR
  1. BBL installer update: June 22, 2008
    Last Post: July 3rd, 2009, 05:28 PM
  2. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:37 AM
  3. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
  4. Minor typo in the June 13th update
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 05:27 PM
