Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 82
Thread: BBL installer update: June 12, 2008
  1. #31
    Nov 2006
    the imperial units in the scan.exe are inHg and
    the tune.exe imperial units are PSI.
    this has been for some time now.
    http://forum.efilive.com/showthread....ight=7.4+issue
    i don`t know if this will cause a problem but i`d like to use
    all imperial settings and not mix and match.
    it may not be a big deal, but it is an annoyance.
    is it just a matter of editing the sae.generic or is there more to it?
  2. #32
    Quote Originally Posted by Ninety8C5 View Post
    I must be doing something really wrong because I did all of the above and it still does not work for me. I've never been able to get this to work.
    In your Scan Tool software in the Properties window on the [Folders] tab page, make sure the PIDs and MAPs settings are pointing to these folders respectively:
    \My Documents\EFILive\V7.5\PIDs
    and
    \My Documents\EFILive\V7.5\Maps
    I'm pretty sure the *.mls file must be located in whatever folder the "Maps" folder setting is set to.
    As a last resort you can turn on startup logging by right clicking on the EFILiv eScan Tool shortcut icon on the desktop and selecting Properties. Then add /l (thats a space, then a slash then a lower case L for "logging") to the Target.
    Re-start the scan tool and then close it.
    Look for the file: \Program Files\EFILive\V7.5\StartupLog.txt
    Open it and search for mls (near the end), you should see something like this:
    Code:
    15:56:53.252|1224|OpenPid C:\Documents and Settings\HP_Owner\My Documents\EFILive\V7.5\PIDs\TEST-CAT.pid
    15:56:53.549|1224|Load MAPs...
    15:56:53.549|1224|*.mls file: C:\Documents and Settings\HP_Owner\My Documents\EFILive\V7.5\Maps\TEST-CAT.mls
    15:56:53.549|1224|mls file exists
    15:56:53.549|1224|MLS %d: %s
    15:56:53.549|1224|Load map: C:\Documents and Settings\HP_Owner\My Documents\EFILive\V7.5\Maps\{B0101} Main VE - LC-1 WO2 AFR.map
    15:56:53.564|1224|Load map: C:\Documents and Settings\HP_Owner\My Documents\EFILive\V7.5\Maps\{B0101} Main VE - LC-1 WO2 BEN.map
    15:56:53.564|1224|Load map: C:\Documents and Settings\HP_Owner\My Documents\EFILive\V7.5\Maps\{B5001} MAF Calibration - LC-1 WO2 AFR.map
    15:56:53.580|1224|Load map: C:\Documents and Settings\HP_Owner\My Documents\EFILive\V7.5\Maps\{B5001} MAF Calibration - LC-1 WO2 BEN.map
    15:56:53.595|1224|Load map: C:\Documents and Settings\HP_Owner\My Documents\EFILive\V7.5\Maps\
    15:56:53.595|1224|Active map set to A
    15:56:53.627|1224|OpenPid done
  3. #33
    Remember to turn off the /l logging option once you've created the log file.
  4. #34
    Quote Originally Posted by mr.prick View Post
    The fix for this problem did not get done. I don't know why yet, but sorry about that. It is at the top of the list to get fixed asap.
  5. #35
    You can edit sae_generic.txt and change the units to PSI if you're comfortable figuring out the conversion factor(s).
  6. #36
    Jul 2007
    Hi All,
    the upgrade went well, though the tune tool came up in demo mode. I used the opportunity to test the connecting of the V2 and checking the license retrieval, which went well. I then disconnected the the V2 and subsequently noticed the "Backup" option under Help - FlashScan V2 VIN Licensing... Clicking on this option with the flash scan disconnected, resulted in an absurdly wide error window popping up with the text " Licence details could not be backed up. No rely." I'd estimate the window is around 15400 pixels wide... I'll see how the rest goes tonight.
    Simon.
  7. #37
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default Serial WIDEBAND WORKS!!!!!
    Hey Guys.... I've got the serial wideband working great and have used it extensively on E38 and once on E67 with NO PROBLEMS.
    However, I can't even connect to LS1's with serial wideband working..... Anyone have this same experience.....?
    I had some connectivity problems and I'm thinking that some of it was not having an SD card installed to save settings.......Wacha think?
    I'll test the LS1 stuff tomorrow first thing.
    Anyone know how to use change the BEN factor of RTACS when using roadrunner with SERIAL WIDEBAND???? I'm hoping it's simple.
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
  8. #38
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    and
    For some unknown reason, my Scan Tool cannot find the TEST-CAT.mls file. I've verified several times that it is in the correct folder, but the StartUpLog does not see it.
    09:26:55.312|3900|Validate connection...
    09:26:55.312|3900|Load customer details...
    09:26:55.375|3900|Load MRU PID selection...
    09:26:55.375|3900|OpenPid C:\Documents and Settings\Owner\My Documents\EFILive\V7.5\PIDs\TEST-CAT.pid
    09:26:56.046|3900|mls file does not exist
    09:26:56.046|3900|Load map: C:\Documents and Settings\Owner\My Documents\EFILive\V7.5\Maps\
    09:26:56.062|3900|Load map: C:\Documents and Settings\Owner\My Documents\EFILive\V7.5\Maps\
    09:26:56.078|3900|Load map: C:\Documents and Settings\Owner\My Documents\EFILive\V7.5\Maps\
    09:26:56.093|3900|Load map: C:\Documents and Settings\Owner\My Documents\EFILive\V7.5\Maps\
    09:26:56.109|3900|Active map set to A
    09:26:56.109|3900|OpenPid done
    09:26:56.109|3900|Load MRU dashboard...
  9. #39
    Check the following two settings in the Scan Tool Properties window:
    1. On the [Startup] tab page, make sure the "Always load dashboard file" checkbox is checked off.
    2. On the [Options] tab page make sure the "Link PIDs and dashboards" checkbox is checked on.
    The *.mls file is processed when the dashboard is loaded therefor it is only "linked" with the PID file name if the dashboard is linked to the PID file name.
  10. #40
    Sep 2003
    It looks like unchecking the "Always load dashboard file" fixed it. It now finds the *.mls file and loads the MAPS.
  1. BBL installer update: June 22, 2008
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: July 3rd, 2009, 05:28 PM
  2. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:37 AM
  3. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
  4. Minor typo in the June 13th update
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 05:27 PM
