Results 1 to 4 of 4
Thread: Switchable Tunes
    Jun 2008
    Default Switchable Tunes
    I'm confused on the loading different tunes from the V2 standalone (BB mode). I know the original manual says you can't do it. I upgraded to the BB beta. The new EFIExplorer lets me download .tun files to the V2. When I try to select it from the "switchable tunes" menu item, I get "This option is not available for the currently selected controller".
    Now, searching the forum for "switchable tune", I read about DSP5. That's not what I'm looking for. I want my stock tune, and performance tune stop and load.
    So, how does it work. If it's a future item, how will it work.
    2005 GTO, 6 Speed, LS2, OS 12598977
    DSP5 is for switching tunes on the fly on the Duramax (my understanding of it).
    What you probably want is to be able to do black box flashing from V2...
    i.e. being able to store/flash tune files to/from the SD memory card...
    I believe this is in the works.
    Jun 2008
    That is exactly what I want. So the answer is "in the works".
    Correct, reading and flashing controllers from the V2 unit in standalone mode is currently being developed.
  1. 5 Position Switchable Tune .. Will this ever be available for LBZ???
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 7th, 2009, 01:39 PM
  2. Converting DSP2 tunes to DSP5 Tunes
    By BlkMax in forum Duramax LB7
    Last Post: March 6th, 2009, 10:14 AM
  3. EFILive DSP² - Duramax Switchable Program²
    By GMPX in forum General (Diesel)
    Last Post: February 22nd, 2006, 01:33 PM
