Results 1 to 3 of 3
Thread: Help flash memory test failed
    Default Help flash memory test failed
    Hi, I have upgrade the the firmware to 2.04.72 then I'm getting a error when trying to upgrade bootblock
    V2 -> upgrade bootblock to V2.5.08 ? no/yes
    The flash memory will now be tested ....... no/yes
    V2 -> erasing block Block xx of 70 counting from 0 to 70
    V2 -> ATTENTION Flash memory test FAILED
    return flashscan for repair
    Did I missed a step or I have a hardware problem ?
    V2 works fine
    Modpcm
    I pm'd tech support.
    No, you have not missed a step, the flash memory in your FlashScan V2 has failed. You must return it to EFILive be repaired. It will be covered under warranty regardless of the age of the unit because the flash memory was most likely faulty from day 1.
    The V2.04.xx firmware does not use the flash memory so it would never show up as a fault until the V2.05.xx firmware is installed. The flash memory test prevents the upgrade because the upgrade would fail if it was allowed to complete.
    Please return your unit to Ira at Fish Tuning in CA (310) 499-0989
  1. failed flash
    By pdasterly in forum FlashScan V2
    Last Post: January 6th, 2010, 05:21 PM
  2. failed flash
    By 69camaro5speed in forum Allison 5 & 6 Speed
    Last Post: January 8th, 2009, 01:58 PM
  3. Flash memory programming.
    By rally1 in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 5th, 2008, 07:44 PM
