Or will I need to bring it to a dealer for Tech2?
not sure vinny...
andy
01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
Vinny,
I'm not sure about your car, but try this:
after installing the new PCM and doing a full flash to it of the tune file saved from your old PCM, do this:
- from scantool send the correct VIN to the PCM,
- from tunetool do the VAT relink (and only that),
- motor should now start,
- verify motor runs correctly (view PIDs to see if they make sense, check for DTC's),
- allow motor to warm up,
- from scantool do the CASE relearn.
Joe
