Results 1 to 10 of 15
Thread: Efi Live Log Not Reflecting Actual Performance
    Jan 2008
    Default Efi Live Log Not Reflecting Actual Performance
    Just finished my log, but efi live didnt record a host of information. It showed my speed as a constant 36 mph the entire time. It showed my mani KPA as a solid 17.1 the entire time, but the efi dashboard showed the gauge moving down when I pressed down on the pedal.
    Whats up guys?
    I really need some help here.
    97 MN6 vette, Vortek, BBK 80 FAST 78 manifold, 42# racetronix, lingenfelter edlebrock heads 202cc, 228 232 .622 .630 111+2, patriot dual ex, yt roller rockers, lg pro, now with cats, .041 Mr. Gasket (cometic leaked), 62cc head, ~60 cc chambers, custom built coilovers, ADDCO sway bars
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    The yellow button is real time monitoring (no recording) and the red is record, gonna guess you hit the yellow? If you hit the red, then I am gonna guess its filtered to show what your viewing. If this is the case take out the filters
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Jan 2008
    how can you tell?
    look at this one, please
    Jul 2006
    The Log Works here.
    You have too many PIDS selected to the scan speed is slowed down.
    35 selected using 42 channels, You want 24 channels or less for best scanning.
    Some PIDs take up two channels, so its not always a one PID = one channel
    Maine USA
    Jan 2008
    do you see that the speed mph and manifold KPA don't change? Is this what is compromised by too many pids?
    would that be because I need to coordinate the values between the scan tool and the tune tool?
    Can they be all metric or all imperal as long as they match?
    Jul 2006
    It does stay steady (but it does change a couple times if you let it play) do another log with 24 channels. Your logging to many things.
    Maine USA
    Jan 2008
    as I'm messing with it the afr set is the command afr not the lc1 afr
    I'm having to find the correct data to show....
    I will reduce the pids and relog, can I get a little help with the short list of critical pids to doubel check my selection?
    Did you:
    - enter the correct VIN/OS...?
    - enter the correct PCM...?
    - validate pids...?
    Do reduce your pid count to 24 (or less) channels (4 packets).
    Is your log captured using V1 BBL mode...?
    If so, then after doing the above steps you have to reprogram the pids into the V1 again.
    Jan 2008
    I don't know what is a bbl?
    here is my new attempt, it's a large file.
    Jan 2005
    BBL = Black Box Logging
  1. commanded vs actual
    By minytrker in forum General
    Last Post: January 23rd, 2009, 03:12 AM
  2. AFR Commanded/ Actual
    By zapp168 in forum Gen III V8 Specific
    Last Post: September 16th, 2007, 01:41 PM
  3. Actual AFR during cold idle
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2006, 08:02 AM
  4. Startup AFR commanded vs actual
    By carneb in forum General (Petrol, Gas, Ethanol)
    Last Post: July 2nd, 2006, 10:23 PM
  5. command vs actual a/f
    Last Post: June 9th, 2006, 12:50 AM
