I understand using this table and setting everything to 14.63 should make the PCM go Close loop, am I correct?
Ok I followed the steps
B4206 Always Use Open Loop EQRatio Tabe : Disable (My Os Didnt have it)
B4205 Closed Loop Temp Enable: Set to max setting (Set mine to 284)
B4108 STFT Idle Enable: Disable
Loaded it into the car and started it let it idle for a while and never went out of open loop. I moniter my afr and it was commanded at 14.68 which my table was set at 14.63. I would give it gas and I would see my afr climb at the points where I adjusted it to.
My question is will the car go into close loop when on the highway if it is hitting the tables where it is 14.63? I know if its not on 14.63 it will go open loop.
I know Disabling STFT IDLE will more than likely keep it in open loop at idle. Is there a purpose to this or this just a technique to activate the Open Loop AFR table. I'm trying to make sure i did everything right
Chris
