Results 1 to 9 of 9
Thread: look at my log(s)
    Jan 2008
    Default look at my log(s)
    I thought I changes everything over to metric, but I guess not.
    Any thoughts on what direction to head in next.
    When I'm under full throttle in high rpm's my timing goes to 0
    97 MN6 vette, Vortek, BBK 80 FAST 78 manifold, 42# racetronix, lingenfelter edlebrock heads 202cc, 228 232 .622 .630 111+2, patriot dual ex, yt roller rockers, lg pro, now with cats, .041 Mr. Gasket (cometic leaked), 62cc head, ~60 cc chambers, custom built coilovers, ADDCO sway bars
    Quote Originally Posted by NASABlue View Post
    That's ok, speed and temperature are just fine in imperial.
    Ok, you got your LC-1 working...
    The next things to do:
    - did you do the heater cal and free air cal on your LC-1 (as said in the LC-1 user manual)...?
    - take some more logs, understand what your car is doing, play with the maps;
    - read the AutoVE tutorial several times;
    - look at the various tables in your tune file mentioned by the AutoVE tutorial;
    - find the thread containing the injector flowrate spreadsheet and check your IFR table... is it close...?;
    You probably want to "correct" your VE table using the AutoVE tutorial, but understand all the steps and why they are required (engineers always ask "why").
    That's not true... timing goes to zero on closed throttle deceleration after a WOT blast... but at WOT it is about 18*...
    see the attached view of your log file.
Name:	Ray Timing does not goto zero at WOT.png
    Here's more views of your log...
Name:	Ray Zoom In 1.png
ID:	3494   Click image for larger version.
Name:	Ray Zoom In 2.png
ID:	3495   Click image for larger version.
Name:	Ray Zoom In 3.png
    And more...
Name:	Ray Zoom Out 1.png
ID:	3497   Click image for larger version.
Name:	Ray Zoom Out 2.png
ID:	3498   Click image for larger version.
Name:	Ray Zoom Out All.png
    Jan 2008
    hey those are good views. thanks
    It's like changing the dwg scale in autocad....but not
    Thanks for the direction.... It gives me something to chew on (on which to chew).
    I did calibrate my lc1 to open air before I ever started the car. even read the directions and used the red button.
    I recalibrated the LC-1 analogue (sp) 1 that went to the efi pid input per the tutorial.
    DO I need to do that to the gauge as well on the ana 2 outpit? THe gauge is the blue lc1 digital supplied AFR gauge.
    Anyway, we're getting there
    Your LC-1 appears to be working: at steady state you can see the actual AFR very closely "trimming" around the commanded AFR.
    Feb 2008
    And like joecar said, do take the time to UNDERSTAND whats happening in the autove tutorial it will keep you from chasing your tail. And use the search button lot of info on this site, although some of it old.....
