Results 1 to 4 of 4
Thread: Injector PW & Duty Cycle
    May 2008
    Default Injector PW & Duty Cycle
    In a drag race only vehicle and you hit 100% duty cycle can you raise the fuel pressure 20% (60psi to 72psi) then reduce your MAP VE 20% accross the board and come out the same AFR? Or is their a different formula to use without starting over on the VE tables?
    Thanks,
    Lee
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
    Sorry Lee but it does not work like that. Fuel pressure rise vs. delivered fuel through the injectors is not a linear equation. Check out Russ Collins' web page for an online formula.
    http://www.rceng.com/technical.aspx#...ressure_Change
    To be accurate after any fuel changes you should put a wide band AFM to verify the change.
    Al
    Member Ritch's Avatar
    Feb 2007
    any concerns about increasing pressure to 70+ lbs? I am considering this.
    ____________________________
    1999 GMC, rcsb, 2wd, 5.3, XR275HR-12
    Radix magnacharger mp112
    Long tubes true duals, $L60E
    Lifetime Member johnv's Avatar
    Jan 2005
    If your VE table is dialed in you should be able to raise fuel pressure, then rescale injector flow rate table useing one of the spread sheets floating around (do a search)
    then you should be good to go
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
  1. Injector Duty Cycle.
    By ssdungeon in forum Gen III V8 Specific
    Last Post: September 10th, 2009, 05:50 AM
  2. injector duty cycle
    By minytrker in forum General
    Last Post: September 10th, 2009, 05:24 AM
  3. Injector duty cycle above 100%
    By ls1vt209 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2008, 04:37 AM
  4. Injector duty cycle..
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 26th, 2008, 07:21 AM
  5. so is 138% injector duty cycle bad?
    By ace68 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2005, 10:44 PM
