I hope what I found is right:
F55E-A2D/E. was tested and it gave: 22.5 lbs @43PSI
here is the source:
http://forums.corvetteforum.com/show...1701576&page=4
If your fuel pump is stock, the rail pressure would be 58 psig. So, following are the required numbers if the rail pressure is 58 psig:
Kpa lb/hr
0------------26.131837
5------------26.294699
10-----------26.456558
15-----------26.617433
20-----------26.777341
25-----------26.936300
30-----------27.094326
35-----------27.251436
40-----------27.407646
45-----------27.562970
50-----------27.717424
55-----------27.871022
60-----------28.023778
65-----------28.175706
70-----------28.326819
75-----------28.477130
80-----------28.626652
