Results 1 to 5 of 5
Thread: 2 LC1's via serial link?
    May 2008
    Default 2 LC1's via serial link?
    Hi All,
    Is it possible to hook up two LC1's via the serial input?
    The wiring solution is nicer than trying to use the analogs.
    Cheers
    Yes... V2 BBL has two sets of serial pids.
    May 2008
    Thats great.
    Is there a diagram as to how to wire two serials up. One is obviously fairly easy, but the stock serial cable only has one input jack.
    Cheers
    Plug in the serial terminator jack/plug into SERIAL IN on WB #2.
    Connect SERIAL OUT on WB #2 to SERIAL IN on WB #1.
    Connect SERIAL OUT on WB #1 to the DB9 null-modem-gender-bender.
    Connect the gender-bender to FlashScan V2 RJ12 input.
    [or you can make your own DB9->RJ12 null-modem cable.]
    See these links:
    showthread.php?t=7532
    showthread.php?t=8115
    http://www.sfcable.com/cable/p/30D1-C1-S.html
    May 2008
    That would make sense
    Thanks for your help!
  1. Link to GM T43 factory calibrations?
    By C6Guy in forum Gen IV V8 Specific
    Last Post: May 14th, 2010, 07:37 AM
  2. {B4105} how do i link this table?
    By mr.prick in forum Tips and tricks
    Last Post: July 5th, 2008, 05:20 AM
  3. Link to MAP
    By TAQuickness in forum General
    Last Post: September 8th, 2006, 04:07 AM
  4. i need a link
    By NviouSS in forum General (Petrol, Gas, Ethanol)
    Last Post: October 13th, 2005, 09:52 PM
  5. VAT Re-link
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: July 13th, 2005, 09:08 AM
