Results 1 to 10 of 13
Thread: Picked up a OLD AutoTap V1
    Default Picked up a OLD AutoTap V1
    Can I use the old AutoTap V1 (RS232) with EFILive still?
    It is the AutoTap/EFILivePro version.
    How do I get older versions of EFILive that work with it?
    EFILive v7 does not work.
    I think it is a AT1EFIPRO. I'll go check....
    The latest version of EFILive works with serial and USB AutoTap cables. A change was made in this latest release to fix a bug that caused the AutoTap cable to not work. So previous versions will not support AutoTap but the latest one V7.5.4 will.
    It is available here:
    http://forum.efilive.com/showthread.php?t=8289
    This one is RS232. It is a KAT1EFIPRO, the AT1 model.
    Ideas?
    Tom, try the V7.5 software in the link in post #2.
    I'll give it a try tonight....
    I found this here: http://efilive.com/faq.aspx
    I have an AutoTap Scan Tool. Can I use EFILive?
    Yes, you may purchase an EFILive registration key that allows you to use the EFILive V7 Scan Tool software with your AutoTap V2-AT1, V2-AT123 and ATU interface cable(s).
    EFILive V7 is not compatible with AutoTap V1 cables KATUEFISTD or KATUEFIPRO.
    Quote Originally Posted by N0DIH View Post
    The AT1 designation is not the version number.
    AT1 means a GM specific cable.
    AT2 means a Ford specific cable
    AT3 means a Chrysler specific cable
    AT123 mean a cable that supports all three manufacturers.
    AutoTap V1 cables come in AT1, AT2, AT3 and AT123 versions, are black and are RS232 serial cables. (Not supported by EFILive)
    AutoTap V2 cables come in AT1, AT2, AT3 and AT123 versions, are black and are RS232 serial cables. (Supported by EFILive)
    AutoTap V3 cables support GM, Ford and Chrysle, are red and are USB. (Supported by EFILive)
    He said it came with EFILive v5. But I can't find V5 out there. Is it still lurking around? It is circa 2003.
    Version 5
    http://download2.efilive.com/Softwar...5SetupFull.exe
    Version 6
    http://download2.efilive.com/Softwar...iveV6Setup.exe
    Mar 2009
    So the V1 and V2 are described as looking the same. Is there a way to tell which we are looking at?
    Look on the side of the AT1 unit and you will either see a silver sticker with a serial number on it or you won't. If the sticker exists then it is a V2, if there is no sticker then it is a V1 (V1's do not have serial numbers).
    If you think the sticker may have been removed, then you'd need to hook it up to EFILive (and a vehicle to supply power), and attempt to connect to it. EFILive will show whether it is a V1 or a V2.
    First image: select the AutoTap V1 cable type.
    Second image: select to connect to FlashScan only - which simply means only make a connection to the interface cable (AutoTap or FlashScan) and not to the vehicle.
    Third image: display the [F6 Console] tab page and view the details that are displayed by EFILive.
ID:	4810   Click image for larger version.
ID:	4811   Click image for larger version.
  1. Can I do anything with this AutoTap cable?
    By spoolin7 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2010, 04:03 PM
  2. Autotap
    By Grey Silver in forum Gen III V8 Specific
    Last Post: November 24th, 2007, 12:40 PM
  3. AutoTap and FlashScan V2
    By CGTMS in forum General
    Last Post: December 20th, 2006, 11:29 AM
  4. Need some help w/ AutoTap and my Ford...
    By ToplessTexan in forum Lounge
    Last Post: December 10th, 2005, 08:57 AM
