Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: Idle Tuning with new pids (calc pid file included
    Sep 2003
    Default Idle Tuning with new pids (calc pid file included
    Here is my calc pid file for idle tuning. with this file and a map you should be able to dial your idle in to a tea on the first try from a cold start to operating temps.
    The correction is directly applied to the Airflow idle table for both PN/in gear and ac on and off. To use these pids with a map set either a row/colum to rpm =8000 and use the respective ECT values to build your tables. Happy idle tuning
    Code:
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter  Value            Description
    VERSION     7.1.1            File version
    DECSEP      .                Decimal separator used in this file
    # Units
    *UNITS
    #Code     System     Abbr     Description
    *CLC-00-000
    gps -32.0 32.0 2 "{GM.IAC_LTDAC_DMA} + {GM.IAC_STD_DMA}"
    *CLC-00-001
    gps -32.0 32.0 2 "{GM.IAC_LTD_DMA} + {GM.IAC_STDAC_DMA}"
    *CLC-00-002
    gps -32.0 32.0 2 "{GM.IAC_LTPNAC_DMA} + {GM.IAC_STPN_DMA}"
    *CLC-00-003
    gps -32.0 32.0 2 "{GM.IAC_LTPN_DMA} + {GM.IAC_STPNAC_DMA}"
    # Add slot definitions here
    #Units             Low          High      Fmt  Expression
    #Code                      PRN  SLOT         Units            System           Description
    CALC.RAFIG F600 CLC-00-000 "gps" CALC "Idle Airflow Correction AC off, in gear"
    CALC.RAFACIG F601 CLC-00-001 "gps" CALC "Idle Airflow Correction AC on, in gear"
    CALC.RAFACPN F602 CLC-00-002 "gps" CALC "Idle Airflow Correction AC on, P/N"
    CALC.RAFPN F603 CLC-00-003 "gps" CALC "Idle Airflow Correction AC off, P/N"
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Sep 2004
    I'm going to show my ignorance here. Will this work if you have an ETC? I have an '04 Corvette.
    \'04 Z16 Corvette, AFR 205 heads, Comp 228/232 114+4 LSA custom cam, HS Rockers, Kooks 1 7/8\' headers, 3\" X-pipe, stock Ti tail section. \'98 Corvette Pace Car, \'04 Chevy Avalanche Z71 4X4.
    Thanks for sharing that Mr Diggler
    I might just have to try that one myself, Cold start idle P/N shift to D can be a pain to get right, you only get a few shots a day afterall.
    Sep 2003
    Quote Originally Posted by Z16DNA
    I dont see why it wont. ETC cars dont have IAC motors and are DEPENDANT on the raf tables for airflow values (moreso than cable actauted cars). No thank you for adding the new PIDS
    Larry - HumpinSS
    Sep 2004
    Thank you, another reason I asked is when I try to select the PID's listed above they all come up invalid. I think this is because I have an ETC car?
    Sep 2003
    Has the scanner validated the PIDS
    Larry - HumpinSS
    Sep 2004
    It should have. I plugged into car last night and all the new IAC PID's list as invalid. Again it could be operator error, but usually an invalid PID become valid once I plug into the car.
    Sep 2003
    Not sure what your problem is but next itme you ahve the scanner connected to the car hit shift + F2
    Larry - HumpinSS
    Sep 2004
    Good idea. I just hooked up to my '04 Chevy Truck, also ETC controlled. Performed shift + F2. Still no IAC PID's. Maybe it's not just me?
    Sep 2003
    Maybe i was wrong about the ETC cars. I guess Ross or Paul will have to chime in on this one
    Larry - HumpinSS
  1. Need FBW idle training(tune included)
    By Slowrc in forum Gen III V8 Specific
    Last Post: March 28th, 2010, 10:06 PM
  2. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 05:39 AM
  3. Please help me with my idle(EFILog Included)
    By RandomHero in forum General (Petrol, Gas, Ethanol)
    Last Post: February 18th, 2007, 12:36 PM
  4. Missing calc.pids
    By VetPet in forum General
    Last Post: December 4th, 2005, 04:01 PM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
