Results 1 to 4 of 4
Thread: DFCO question.............
    May 2006
    Default DFCO question.............
    Hi Guys!
    I've finally got my VE table pretty close and was wondering if it'd change alot if I modified my DFCO settings
    (made them more aggressive). If so, when I log and then before loading the changes, can I filter those out of the log or should I adjust for it in the tune?
    If filtering them, which filters should I use?
    Thanks in advance!
    Lifetime Member johnv's Avatar
    Jan 2005
    you should have had DFCO turned off when you dialed in your VE table otherwise DFCO would scew your results in cells where it is active.
    enableing it again after and makeing it more aggressive will not alter VE, just how soon and at what MAP and RPM it can be enabled. It is a fuel cutoff not a fuel miltiplier.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    DFCO is not accounted for in the commanded AFR pid... as Johnv said you must have it disabled during AutoVE.
    May 2006
    Thanks Guys!
    So then once I get my VE table dialed in, I'll turn it back on.
  1. DFCO question...
    By The Alchemist in forum General (Petrol, Gas, Ethanol)
    Last Post: February 8th, 2013, 04:25 AM
  2. dfco
    By VUR8Maloo in forum Gen III V8 Specific
    Last Post: June 30th, 2009, 12:40 AM
  3. DFCO with ECT
    By vzsv8 in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 02:57 PM
  4. Dfco
    By purrvert in forum Custom Operating Systems
    Last Post: May 27th, 2007, 02:43 AM
  5. DFCO vs ETC TP?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: December 26th, 2006, 11:11 AM
