Results 1 to 10 of 11
Thread: Is there a supported vehicle list for V6?
    Default Is there a supported vehicle list for V6?
    Does anyone have a supported vehicle list for EFILive V6?
    If it is OBD-II with VPW protocol (i.e. 1997-2007 GM), then there's a good chance you can log from it.
    Is V6 scan only or is it flash and scan?
    I got the impression it would flash too, that is what it was originally bought for.
    Tom,
    V6 flashes also.
    You can upgrade to V7 software (you will need to get a new cable registration license).
    All the software is free.
    You have FlashScan V1 that you run V6 on, right...?
    Got it working with V7.5, so far at least, it does support the AT1 RS232 interface.
    Now to see what I can do with it....
    But on the V6 question, it flashes, but what vehicles? I can't find a list anywhere. I have the v7 scan license.
    Quote Originally Posted by N0DIH View Post
    You won't be able to flash using the AT1 interface.
    To flash, you need a flash+scan license, and an unused PCM license.
    Flashable Vehicles: http://www.efilive.com/supvehicle.aspx
    Mine is a AT1 V2, which means it will flash. Not to be confused with EFLive V2. It is the 2 way version..... I guess I will have to try!
    Oh, I see.
    EDIT: it won't work.
    EFILive does not support reading or flashing any controllers through the AutoTap interface. You must use a FlashScan interface for flashing.
    So, what you are saying, is the V7.x version of EFILive is the FIRST version to ever FLASH a PCM?
    I was under the impression V5 and up could flash with the EFILive V1 or V2, or the AutoTap AT1/AT123, V2 and later or ATU.
  1. is this ecu supported?
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 10th, 2010, 12:56 PM
  2. Supported Vehicle list confusion
    By 01Z in forum Purchase and Shipping
    Last Post: April 7th, 2009, 09:16 AM
  3. E38 supported OS wish list
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2007, 01:20 AM
  4. Vehicle not supported?
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2006, 04:33 PM
  5. List of supported pcms/model?
    By rattle in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2004, 10:39 AM
