Results 1 to 10 of 11
Thread: Hummer 6.0 tunes??
    Apr 2007
    Default Hummer 6.0 tunes??
    I am in desperate need of a econ tune for a 2007 H2 SUT with 6.0 motor. Anyone able to help me?? Even a 2500HD tune would give me something to go off of enough to tune the hummer.
    THANX!!
    Jan 2005
    Trying to get decent fuel economy out of a hummer is like trying to get a pig to fly-- somewhat difficult. It's tough to have any kind of fuel economy when you're dealing with a 6,000+ pound vehicle. But improvements are possible. To a point, getting the transmission into the highest gear as quickly as possible will help. But you have to trial and error test-- if you get too aggressive, the engine load will be excessive (relative to optimized shift points) or the trans will be continually downshifting and fuel economy will get worse. Using more aggressive DFCO (decel fuel cut off) settings will also make a noticeable improvement. Factory settings tend to be overly conservative. Spark timing can also be a source of improved fuel economy. The optimal settings are a function of fuel octane, altitude and driving style. I wouldn't be too quick to use a 2500 tune file unless you can get ALL the necessary details. The vehicles are different enough that unless you've been down this road before, you may actually be taking a step backwards by doing so. I'd start with the existing file and make the necessary mods. That way, you know what you're dealing with and won't spend time chasing issues related to file/vehicle compatibility.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Oct 2006
    I feel your pain I have a crew cab 1500 HD with a 6.0L in it and it is tough to get any kind of mileage from it , heavy vehicle , lots of mass to get going .
    I run a COS3 for the purpose of better mileage and I can tell you can get to a point that mileage goes to here and that is all you can get .
    Good luck , DFCO and faster shifts help some , have never seen any proof that changing injector millivolts helps any ,timing in certain places helps some also .
    2006 Trailblazer
    Apr 2007
    Anybody ever come up with any tunes for the Hummer 6.0?
    Just got one, Every little squeeze will help.
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2006
    Try the new .cax files and see if you can get "lean cruise" to work , that will help quite a bit .
    2006 Trailblazer
    Apr 2007
    .cax files?
    Something new with a new version? I've been working with the same release for the past 6 months or more. Just the first release that included LMM. 7.2?
    Apr 2007
    Quote Originally Posted by tunedbyGM View Post
    What are you seeing for mileage on you 1500HD?
    I have tuned a coulpe of them and they were getting 12 now they are at 14.
    Oct 2006
    Quote Originally Posted by MSURacing View Post
    I get 13 city and 17.5 highway , with a new cam (Comp 54-412-11) and Pacesetter LT headers , no LC yet .
    Gil
    2006 Trailblazer
    Feb 2009
    what type of ecu does the 04 have
    Jun 2009
    i have a 06 h2 and i can do any better than 19L/100km city or highway driving....would love to try a new tune
    99 a4 corvette
    3800vig tc ,rpm level 5, 317 heads,a&a blower cam,a&a s trim 10psi,3.42,tsp headers,hi flow cats,borla cat back,550rwhp no meth yet
  1. Hummer H2
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2011, 10:15 AM
  2. O3 Hummer
    By teddyls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 25th, 2010, 08:38 AM
  3. Converting DSP2 tunes to DSP5 Tunes
    By BlkMax in forum Duramax LB7
    Last Post: March 6th, 2009, 10:14 AM
  4. 07 Hummer
    By FFP in forum General (Petrol, Gas, Ethanol)
    Last Post: November 21st, 2006, 03:10 PM
  5. 05 Hummer
    By Forcefedperformance in forum General (Petrol, Gas, Ethanol)
    Last Post: May 1st, 2006, 03:42 PM
