Results 1 to 3 of 3
Thread: 512k or 1024k Road Runner???
    Jan 2007
    Default 512k or 1024k Road Runner???
    OK...so it's nearly midnight....AGAIN!
    I've been reading all of the threads in this section of the forum and I see others have had exactly the same issue I'm having....unfortunately there's not many follow up posts so I don't know how/if they cured their RR ill's.
    I did notice when I installed my RR kit that the pcb said 1024k on it.
    I thought that was odd...as I was of the belief that my PCM is 512k...but....I really don't know enough about that stuff.
    Is this an issue I need to worry about?
    I'm using the LS1 0411 PCM.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Lifetime Member limited cv8r's Avatar
    May 2005
    mine is the same,so shouldn't be an issue.
    Jan 2007
    Thanks...just clutching at straws here....trying to figure out what the issue is with mine dropping out all the time.
    I see 'Billyjo' has/had the same issue.. http://forum.efilive.com/showthread.php?t=6547 ..wonder if he got it fixed?
    Howard
    DUCT TAPE.
  1. Road Runner is frustrating me
    By billyjo in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 2nd, 2007, 03:46 AM
  2. Need help with Road Runner ASAP
    By esco35m in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 31st, 2007, 04:41 PM
  3. Can't connect to Road Runner
    By BlownAlaskan in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 7th, 2007, 02:46 AM
  4. Road Runner DEAD????
    By Highlander in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 13th, 2006, 03:12 PM
