Results 1 to 6 of 6
Thread: Explorer won't connect....
    Oct 2005
    Default Explorer won't connect....
    ...after shutting down once.
    I need to do a repair install every time to be able to connect to my V2. Only time it will connect is right after the install.
    This has been an issue ever since I did the last full install and did not get fixed with the June 22nd update.
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    Are you running Vista?
    If so, it may be a permissions problem with starting up the EFILive_Hapi.exe program.
    Oct 2005
    No, running XP SP3.....and it used to work until revently.
    As a last resort try this:
    1. Uninstall V7.5.4 and V8.1.1 (if 81.1. is installed)
    2. Rename the \My Documents\EFILive\V7.5 folder to \My Documents\EFILive\V7.5_old.
    3. Delete the \Program Files\EFILive\V7.5 folder
    4. Run Regedit and delete the key \\HKEY_CURRENT_USER\Software\EFILive\V7.5 key and all its subkeys
    5. Re-install EFILive V7.5.4
    6. Re-install EFILive V8.1.1
    7. Copy any files that you had modified (that you want to retain in V7.5.4) from \My Documents\EFILive\V7.5_old to \My Documents\EFILive\V7.5
    When you can't connect, do this:
    - exit EFILive Explorer (EE),
    - start Hapi,
    - start EE,
    Does it connect now...?
    On your EE shortcut, do rightclick->properties and make sure that Start In says "C:\Program Files\EFILive\V8.1\Programs".
    Oct 2005
    - start Hapi,
    - start EE,
    YES
    The \Programs was missing now it connects as it used to
    Thanks !
  1. Where do I find EFI Explorer?
    By trailshredder in forum General
    Last Post: April 30th, 2009, 07:59 AM
  2. Problems with efi explorer
    By 2500HeavyDuty in forum FlashScan V2
    Last Post: March 5th, 2009, 09:04 AM
  3. Having trouble with E-Explorer
    By Tony @ MPH in forum FlashScan V2 BB Logging
    Last Post: January 3rd, 2008, 03:34 PM
  4. Explorer questions
    By Ira in forum FlashScan V2 BB Logging
    Last Post: December 30th, 2007, 02:30 PM
  5. EFI Explorer and Time Travel
    By dfe1 in forum FlashScan V2 BB Logging
    Last Post: December 13th, 2007, 11:03 AM
