i was in the process of doing the bbl updates and had gotten pretty far. i just downloaded the v8 and was trying to update the boot block and it is now stuck in dead poll. 2 lights are flashing and cant figure out what to do.
That is normal, it's waiting for the firmware to be updated. Here is a snipit from the readme doc.
To be able to program a new boot block into FlashScan or AutoCal, it MUST be operating normally under firmware control. When you click the [Program] button in EFILive_Explorer, the boot block will be updated, and then the first sector of the firmware will be deliberately erased. The deliberate erasure forces FlashScan or AutoCal into dead poll mode until new firmware is programmed. So after a successful boot block upgrade, FlashScan or AutoCal will enter and stay in dead poll mode until new firmware is programmed into it.
Hope this helps
04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
yeah i figured it out. i had to go into the explorer and figure out which boot block was in there, then i matched it to the proper firmware from another thread. then repeated the procedure using the latest boot block, and firmware. you read the same things enough times the answer is right there. then i calibrated the internal memory for bbl. i did not do the flash card because i dont have one yet and i am pretty sure you need it to format it. thanks anyway.
you can not flash tunes yet with just the flash scan correct?
Glad you got it working man!
No, you cannot BBF yet, soon hopefully! BBL seems like its been stable over the past 2 months, I havent had a problem (except with a VPW DTC thing that was fixed a few updates ago). Ive heard once BBL is done then BBF will commence!
If you stop drinking so much you won't get stuck in dead pole mode.
