Results 1 to 8 of 8
Thread: Low-High Spark tables...
    May 2008
    Default Low-High Spark tables...
    If you put the same numbers in both tables will the computer still monitor spark knock?
    I beleive that if it did register knock that since both tables are the same the computer will not pull timing, is this correct? And will it still record knock?
    The reason I'm asking is that at the track when I get on the T-brake and 2-Step the computer registered knock and it pulled timing for the entire run even though it stopped registering knock after that point. I do not want this to happen yet I still want it to record if there's any knock.
    Lee
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
    Jan 2007
    I believe you will still retard the timing, making both of those tables the same I don't think it will accomplish what you want... Check out table b6205
    May 2008
    It says in power enrichment mode, I beleive that with speed density mode it never gets in PE mode, I think....
    Jan 2007
    I run SD mode (cos3) and I have PE enabled.... You just have to have it enabled...
    Oct 2006
    Setting your low & high octane table to the same values will not prevent knock retard as such. These tables are to allow the engine to learn away from the knock threshold when bad fuel/ lower octane fuel is used. The percent of each table used can be logged with the ASPARK pid.
    Knock retard is set from B6203 etc.
    I would only be playing with these settings with knock phones on the dyno to prevent engine damage.
    The Tremor at AIR
    Lifetime Member johnv's Avatar
    Jan 2005
    It may pay to log all the spark retard pids to see what exactly is pulling the timeing, May be burst knock due to higher than expected airflow, which can be removed in the tune B6212.
    Also increase the knock recovery rate B6207 .
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Feb 2008
    I would go ahead and zero out burst knock at the appropriate temp range. Also what does it mean to quit registering KR. Like the scanner didnt show KR but timing was being pulled from something else?
    '04 ecsb Chevy: 4.8L turbo ,EFILive tuned
    May 2008
    Thanks guys for the help.
    I changed both maps to be the same last week and when I went back to the track there was no activity on the knock sensor, KR was 0 the entire runs. So either the problem was fixed and there's no knock or by changing both maps to be the same numbers disabled the KR. Maybe tonight I'll throw more timing in and see if it registers any knock.
    Lee
  1. Spark High Octane table
    By SHOGOR in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 02:53 AM
  2. Help my spark advance is too high
    By Big Block in forum Custom Operating Systems
    Last Post: April 25th, 2008, 04:48 PM
  3. high/low octane spark tables.
    By s10mods in forum Gen III V8 Specific
    Last Post: December 23rd, 2007, 12:44 PM
  4. High/Low Octane Tables Canada Vs. USA?
    By n6oli in forum Gen III V8 Specific
    Last Post: June 13th, 2007, 04:18 AM
  5. High/Low Spark Map
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2006, 08:27 PM
