Hello everyone. I have been reading and learning on here for a while and tuning my 99 LS1 A4 Camaro with EFI Live (purchased from greenlight). I have installed the following mods: innovative wideband, comp 228/232 cam, Dart 225 heads, pacesetter headers w/ory, LS6 intake, svo 30 lb injectors, underdrive pulley, !air, !egr, TCI 3500 ssf converter, and 3.42 gears.
I upgraded the OS to a 2002 to make tuning easier. I have been mainly working on driveability tuning, and this is my first time tuning a computer controlled car. I have done RAFIG/RAFPN, AutoVE, adjusted spark, and spent countless hours tweaking the cracker/follower and learning tables. Driveability is now pretty good and I'm ready to take it to the track for some WOT tuning.
Which brings me to my questions. From what I have read, my target AFR for PE mode should be 12.5 - 13.0. Is this correct? I am running with a maf and closed loop. Do I need to set it up in speed density mode to tune the VE table for PE mode? Or does it even read the MAF when running WOT? I know it's not using the 02's. Is it possible to do AutoVE for PE mode? Basically, can someone walk me through the steps for tuning PE mode? I know it's the easy part of the tune but I think it would go much faster if I had a little guidance. I don't get down to the track often and want to make the most out of my time.
Thanks for any help.
