If your avereage duty cycle is 89% and peaks at 105% how much power is left behind? I can still command AFR's as low as 12.25 and the wideband O2 shows it so it's not running lean I'm just curious if it's hurting perfornamce or not.
I just ordered 36# injectors so the problem will be solved it's just that the et is .3 slower then I was hoping for and I hope that the new injectors might find some of that et!
Lee
