ok I need to log my fuel pressure. can someone walk me threw the steps of this. Main reason for this is to see if my lift pumps are working.thanks
04.5' LLY Duramax, 20" moto metal 959's Nitto 420S tires,T-bars leveled, 3" drop shackles, EFI live V2 w/ DSP 5, MPI twins, Big dipper 40% nozzles, 5" straight pipe exhaust, Raptor 150 lift pump, Suncoast IV tranny, built by M A, Cognito braces and SD tie rod braces.
You just need to log the desired and commanded fuel pressure PID's. That will show you how well the system is keeping up with the fuel demands.
OK I'm pretty new at this too, but I'll try and walk through what I know.
Open scan tool, plug into truck. Click the green connect to vehicle button on the top left.
Now click on the PIDs tab. Click the clear PID selection icon. Now just below the connect/disconnect from vehicle buttons is an icon with a green check mark, click that or just press shift and F2. Click the supported box to get rid of the ones you can't monitor anyway. Then you can select the PIDs you want to monitor. The caption for actual fuel pressure is FRPACT and the one for desired is FRPDES
He must have quoted a spammer's post that was removed.
