Does the VE {B0101} control the AFR at Idle and does he Desired Airflow {B4307} contribute to it as well....
Corey
Corey
ttt...
B0101 will affect idle AFR. B4307 is for idle correction. To tune B0101, you can use the AutoVE process and filter on idle cells (filter out non-idle). To tune B4307, you need to do the RAFIG process. Search on both and you will find the tutorials.
2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
Check Out My Latest Tune File: HERE
