Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 101 to 110 of 127
Thread: Installing the V7.5 Software
  1. #101
    Apr 2007
    It will still work with EFILive no problem with 4GB. EFILive does not require anywhere near 4GB, it should never need more than about 200MB of memory.
    The largest memory requirement of EFILive is when loading large log files, here's some numbers to help put it into perspective...
    The EFILive software only uses about 200MB when displaying a 500,000 frame log file. A 500,000 frame log file is about 3.5 hours of continuous data logging.
    I just recommended 8GB because Windows itself works better/smoother/faster with more memory.
    Thanks again I appreciate it !
  2. #102
    Sep 2013
    Having trouble installing v7.5 on a microsoft surface pro 2 using windows 8.1. Downloads the whole way, then comes up 'This App can't run on your PC' when you click the setup download. What are we doing wrong?
  3. #103
    These are the system requirements for installing the V7.5 software:
  4. #104
    You have Windows SmartScreen enabled. Either reduce the level in the Windows OS or right click the setup file, at the very bottom you'll see a "Security" section. Check the "Unblock" checkbox, click OK, double click to run. It will work just fine. You will need to do this on any future updates (and for a bunch of other apps).
    I find it's a headache, so I personally disable it. I would not recommend this unless you are an experienced user who knows how to deal with potential virus/malware issues.
    Good to know those are the minimum requirements! 100MB of RAM, don't get too crazy here Paul!
  5. #105
    No one should ever need more than 640KB on their PC
  6. #106
    Remember in the late 1970's when the TRS80 came with 4KB RAM, and Tandy/RS offered an upgrade to 16KB... everyone said "why do you need so much memory?"
  7. #107
    Jun 2011
    installed the latest version of efilive. now getting this error on v7.5 tune tool. all else seems to work correctly. any ideas? this is the first update i have done since upgrading my machine to windows 10. the pervious version worked correctly without issues after the windows update. i am an admin and only user on this PC. Click image for larger version.
  8. #108
    Although you are admin are you running the software as admin ?
    Try right clicking on the EFILive V7 icon and select "Run as admin" to see if that cures it.
  9. #109
    Jun 2011
    Yes I am
    Sent from my SM-G960U using Tapatalk
  10. #110
    Jun 2011
    I tried uninstalling and re installing a few times. I deleted efilive from registry editor. And re installed software. Nothing seems to work. I'm stumped and usually pretty good at this stuff.
  1. Installing the V8 Software
    Last Post: April 18th, 2022, 11:39 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
